119 Users Online (118 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> inserting images into families
Fri, Jul 31, 2015 at 7:36:00 AM | inserting images into families
jamesm2505
Is there a way to embed an image (not link it) into a Revit family file? I am creating a new A4 titleblock and need my company's logo on it, on the A1 template it is a filled region but cannot scale down (line is too short error). Using a .bmp solves this issue but means the image is lost and replaced with a file path when opened on a different computer. Is there a solution to this or do I need to find a different approach?
Fri, Jul 31, 2015 at 9:40:54 AM | inserting images into families
CDWdavid
5 Stars: 5 Votes
Try following steps:
1. Click "Insert", under "Import", click "Image", select your company logo, which should be a raster image file such as .bmp, .jpg, .tif,... format.
2. Place it onto your titleblock, click that image, resize it by drag the dot at each corner, move to the proper location, just like you are doing in Word.
Edited on: Fri, Jul 31, 2015 at 9:42:25 AM
Fri, Jul 31, 2015 at 10:07:49 AM | inserting images into families
jamesm2505
Thanks, that is the method I have been using though - it links the file so when opened on a different pc does not show correctly
Fri, Jul 31, 2015 at 10:14:36 AM | inserting images into families
Images are not linked in Revit.  When you export a Revit file to CAD, then the embedded image is linked to the CAD file.   Is that what you are doing?  If so, you should have said so.
Inserting multiple Families causes project to freeze
Fri, Jul 11, 2008 at 3:28:41 AM
Inserting Families along a Model Line
Mon, Jan 24, 2011 at 9:15:01 AM
Error in the number of images in the Gallery...
Wed, Jul 16, 2008 at 4:43:04 PM
render appereance images missing
Wed, May 11, 2016 at 3:12:18 AM
FOUR FREE REVIT FAMILIES >> Click Images to Download!!
Wed, Feb 2, 2011 at 12:21:35 PM
Page generation time: 1.2207
