37 Users Online (35 Members):
Forums >> Revit Building >> Technical Support >> MODEL TEXT IN FAMILIES IS THERE A BUG IN HERE?
89 Posts No Rating |
when using model text in a project
the text is placed on the face of the reference plane which faces the viewer
(or in plan view it is between the reference plane and the viewer)
and here it is clearly visible displayed as a "ghost" at the end of the curser prior to inserting,
which to me is the logical way.
not so when in a family:
if the front elevation is selected to work in and the work plane selected is
centre front back
and when picking the modeltext button the text does not appear at the end of the curser
one is not prompted to select a work plane and one has to go to tools to set the worplane.
after inserting the text, it is visible in all views except the one you are working in
fantastic.
one way to see the text is to push it bacwards away fron the reference plane
or insert it in the back elevation as i was told by the vendor
what am i doing wrong or what is wrong with the model text?
why can't revit stick to the same method as in projects
robert
melbourne
Text problem on 3D views |
Tue, Nov 9, 2010 at 8:20:38 AM
Text in Families |
Mon, Nov 17, 2008 at 10:27:15 AM
Text in Families |
Fri, Jul 21, 2006 at 11:34:55 AM
REVIT 2011 BUG OR NOT BUG? |
Mon, Dec 6, 2010 at 6:28:30 PM
Text in Families to align to bottom of sheet |
Sun, Nov 21, 2010 at 9:10:23 AM
Members: | 2022396 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
