121 Users Online (119 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Scaling dwg's in families
Mon, Mar 27, 2006 at 11:52:17 PM | Scaling dwg's in families
Rusyel
I have created a family which has a 3D dwg file inserted into it. I have created a parameter which controls the scaling factor of the dwg so it can grow or shrink in the poroject. When I flex the parameter in the family it works fine but when I place the family in the porject the dwg won't scale even though the parameter changes as expected. Has anyone come accross this?
Tue, Mar 28, 2006 at 3:32:36 PM | RE: Scaling dwg's in families
arccodex1
3 Stars: 1 Votes
Maybe you can post the family. I tried importing a dwg and attaching a parameter to it. It wouldn't stretch for me at all.
Tue, Mar 28, 2006 at 4:36:12 PM | RE: Scaling dwg's in families
Rusyel
Attached is the family im working with. You will see that the dwg scales fine in the family editor, If you can get the dwg to scale once its in a project let me know. Post edited on 2006-03-28 16:36:54
Wed, Dec 16, 2009 at 10:37:41 AM | Scaling dwg's in families
johnpaulrogers
Does anyone know whether there is a solution to this? I am also having this kind of problem in Revit Architecture 2010. Cheers, J-P
10 New REVIT 8.1 'Families' Video Tutorials released
Tue, Oct 2, 2007 at 12:39:43 PM
Is anyone successfully importing dwg's without problems?????????????????????????
Wed, Jun 3, 2009 at 12:39:13 PM
Dwg Site Import
Tue, Feb 21, 2006 at 5:12:40 PM
Incompatibility between ''Bluebeam'' pdf fillar and Autocad dwg.
Wed, Aug 19, 2020 at 7:59:03 AM
Corrupt Dwg? - Can't load families [ 1 2 ]
Thu, Jul 16, 2015 at 10:55:31 AM
17
Page generation time: 2.2779
