35 Users Online (34 Members):
Forums >> Revit Building >> Technical Support >> Demolishing wall layers
So I am working on a renovation project where we have multiple phases. In my phase 2 demolition I created parts on an exterior brick on wood stud wall and deleted the brick. However it is still showing up in phase 2 drawings. I have checked the phases to make sure all is in order and as far as I can tell it is. Any help would be appreciated.
Thanks,
AAron
I believe you need to set the parts in the existing phase, uncheck the phase demolished by original then in new phase you can demo that part.
We still don't use parts because we see problems. Parts seem to be view specific.
Thanks WWhub, view specific make sense as to what I am seeing. Any way to do this besides making two walls. Studs and sheathing, and a brick wall and demolishing the brick "portion"? My problem is it is showing up as full thickness and I want those couple of extra inches. Thanks
No easy solution. We have always used two walls.
I made a "hidden" (not shown on any sheet) phase and just demolished it and built a new 2x wall in the same hidden phase. Next time I think I will make it two walls.
wall layers not wrapping at curtain wall inserts! |
Fri, Mar 4, 2016 at 10:27:08 PM
Scheduling Wall Layers |
Wed, Nov 4, 2015 at 11:24:08 AM
Wall Layers in Section Views |
Wed, May 5, 2010 at 3:46:43 PM
Wall Layers Modify |
Fri, Dec 31, 2004 at 8:41:03 AM
Seperating layers hatch with filter |
Wed, Feb 12, 2014 at 3:15:30 AM
Members: | 2037258 | Objects: | 23017 | Forum Posts: | 152210 | Job Listings: | 3 |
