161 Users Online (160 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rooms
Mon, Jul 27, 2015 at 9:08:26 PM | Rooms
glenlake
3.5 Stars: 3 Votes
Good afternoon everyone;
I would greately appreciate  greately if anyone share experience in working with rooms in section view: what is the best way to create one roon above another within the same floor, without creating a level for the second room?
How to select rooms without using filters?
 Thank you.
Tue, Jul 28, 2015 at 7:42:27 AM | Rooms
Rooms are created in plan views, not section and rooms are related to levels.
You can create a level without plans if you need to.
Room heights will define the top of your room.
Tue, Jul 28, 2015 at 7:59:05 AM | Rooms
glenlake
3.5 Stars: 3 Votes
Thank you.
You are the last instance to seek knowledge, when other ways do not work.
If WWHub says it is impossible to do in Revit, so it is impossible.
But it would be nice to "Stack" rooms in section views, wouldn't it?
Thanks again.
Tue, Jul 28, 2015 at 8:03:31 AM | Rooms
If you place the rooms in a stack, they will tag correctly in section views.
Wed, Jul 29, 2015 at 8:27:37 AM | Rooms
glenlake
3.5 Stars: 3 Votes
Yes, they are taggable perfectly in sections, but how to stack two rooms at the same level?
One level has only one room calculation value.
Wed, Jul 29, 2015 at 8:44:03 AM | Rooms
Let's start over.  It is apparent that what you may want is not what you are asking.
A room is always associated with a level, I already explained that.  So you can't have a room on the second floor that reports as being on the first!
But you can set the height of a room to span from the first through the second level.  And you can have multiple rooms on different levels report in the same schedule.
So eplain better what your final needs are.
Wed, Jul 29, 2015 at 10:43:14 PM | Rooms
glenlake
3.5 Stars: 3 Votes
Good evening, WWWHub;
Thank you for the reply.
I am trying to find out if it is possible to make two different rooms, each of which belong to the same level, but one of them is above another.
 Could this be done in Revit 2013?
rooms??
Tue, Oct 29, 2013 at 11:10:18 AM
Deleting Rooms from Schedules
Tue, May 8, 2012 at 8:30:32 PM
Rooms within Rooms? I think...
Tue, Nov 9, 2010 at 11:45:56 AM
Programming spaces/rooms in Revit
Fri, Jun 21, 2013 at 9:20:34 AM
REVIT 15: Can not place rooms on upper and lower levels....
Tue, Feb 12, 2019 at 4:58:36 PM
Page generation time: 0.4351
