81 Users Online (80 Members):
Forums >> Revit Systems >> Technical Support >> Changing the detail level settings
I'm currently running Revit MEP 2015 and drawing Electrical. My problem is the conduit isn't changing to single line when I have it set to medium detail level. How do I change this setting to show single line when in medium detail?
Do you have a view template assigned to this view? Look at the detail level setting there.
I don't have a view template assigned to this view.
Well.... did you at least look at the VG, detail setting for conduits in the view you are using ????
WWHUB,
You got me on that one, thank you! Someone had set it to fine detail instead of by view? The other problem that I'm having with the conduit is the rise and drop symbols are not working properly. I have set these in the MEP settings for what symbol I would like to see when drawing up / down but for some reason when I try and draw a drop it still comes in as a rise symbol. Any thoughts on this?
Changing the detail level in a large group of families...... |
Mon, Aug 26, 2019 at 4:44:53 PM
Coarse, Medium, and Fine Settings |
Wed, Dec 28, 2011 at 12:27:19 PM
sloping beam system? |
Thu, Apr 20, 2006 at 4:56:36 PM
View Scale to Detail Level Correspondence |
Fri, Aug 15, 2014 at 1:28:19 PM
Wall Detail Level |
Mon, Oct 27, 2008 at 2:25:34 PM
Members: | 2056445 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
