Forums >> Revit Building >> Technical Support >> label arrow and instance parameter
Fri, Jul 24, 2015 at 7:01:38 PM | label arrow and instance parameter
Warchitect
4 Stars: 5 Votes
I need to make this four way arrow symbol for site photos. I made one. and added the four labels corresponding to the four directions. Like an interior elevation marker sort of. But when I copy it, (to get photos 5,6,7,8 etc) and change the numbers all the copies update with the new numbers, insted of being its own instance...im doing somthing wrong, but I dont know what. also once you apply the label you cant go back to edit it,..ie. check the name, instance parameter, units etc... here is a pic and the symbol.
any help would be awesome.
Instance Parameter to control another Instance Parameter
Thu, Jul 22, 2010 at 6:22:48 AM
label parameter formula
Thu, Apr 26, 2012 at 12:15:03 PM
Instance Shared Parameter??
Fri, Jul 11, 2014 at 2:49:26 PM
Label - Generic annotation - parameters
Thu, May 17, 2007 at 10:03:54 AM
INSTANT PARAMETER SCHEDULEABLE
Wed, Jul 11, 2012 at 2:08:57 PM
Page generation time: 0.6155
