120 Users Online (119 Members):
Forums >> General Discussion >> Wishlist >> sheet view order
Does this (or could this) exist....
Say I have the following views....they currently appear alphabetically in the plan view list:
T/ Masonry: 12'-0"
T/Slab: 0'-0"
Roof: 14'-0"
When I create them, I'd like them to show in the order of their elevation height instead:
Roof: 14'-0"
T/ Masonry: 12'-0"
T/ Slab: 0'-0"
I've noticed if I change the name plotted/shown on the detail marker, that can affect the list order, but I don't always trust the fellow workset users to not mess something up there. Is there currently a setting that puts them in order of elevation height? Because that would be awesome, especially when I have large lists and alphabetically does nothing for me!
You can add a Project parameter to the sheet and then in your Browser Organization Properties set it to filter by that parameter. For example create a Project Parameter called Sheet Order, then in the properties you would have to put a number in the Sheet Order parameter such as
1 = Roof: 14'-0"
2 = T/ Masonry: 12'-0"
3 = T/ Slab: 0'-0"
Then you can set your Browser organization to Sort by Sheet Order.
As I was going thru the steps you suggested, I came across an even better solution:
- View tab, Windows panel, User Interface dropdown: Browser Organization
- Select/check: "All Disciplines", then edit
- Grouping tab, at the bottom change Sort by to: "Associated Level" and choose decending; okay, apply...
BINGO!
Thanks so much! :D
View List doesn't have parameter to show them in order of number on sheet? |
Fri, Aug 26, 2016 at 2:48:10 PM
controlling drawing order of views on a sheet |
Mon, Mar 7, 2011 at 12:30:49 PM
Element ReNumber and Sheet Order Apps |
Wed, Sep 23, 2009 at 5:54:20 PM
SHEET INDEX ORDER |
Sat, Dec 12, 2009 at 9:14:52 AM
View Overlay Order on Sheets |
Wed, Mar 25, 2015 at 2:53:03 PM
Members: | 2042293 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
