Forums >> General Discussion >> Wishlist >> Revit Schedules Defined Width
I placed this comment here because i figured it would be a wishlist topic, but anyone, corect me if i am wrong. Is there a way to set a pre-set width to your collumns in schedules, so when you create them it makes them a user0defined length? probabbly asking too much, but it realluy would be nice, whiling i'm standing on spool # 60 over here, =). Maybe even a way to set a "template based settings" similiar to views, but for schedules to use.
Create the schedule in your template and place it on a sheet where you can set the widths.
Yea that is the prceoss i am doing now. I was just seeing if there was a way to keep the width, when duplicating, or a way to pre-set the widths so i do not have to manually resize them on the page. I have 3 schedule per page and like 60 pages, it would save me a lot of time if there was a way to avoid that.
ARe all the schedules the same parameters.... just different filters for data?
If so, schedules can be imported so try this:
- On the first schedule sheet where you have everything set, remove all views except for the schedule.
- Without closing your file, create a new project (no template).
- Working in that new file, use import views from file to import that first schedule sheet.
- Renumber this sheet in the new file with a sub number like '-2'
- In this new project, edit this imported schedule changing the name and filters to match your second schedule
- Now you have a new schedule already sheeted - import this into your main project.
- Go back to your new project and again do 4 (sheet sub name '-3'), 5 and 6
- Continue for your 30 schedules.
- Get rid of your old sheets and schedules (except for the very first) and rename your new ones.
This works because I tested it.
Got it. That worked like a charm, thank you HUB, greatly appreciated.
Schedule Width |
Fri, Sep 23, 2011 at 3:18:27 PM
Door Schedules |
Mon, Aug 15, 2005 at 6:11:16 PM
key note and schedule font |
Tue, Oct 26, 2010 at 9:28:33 AM
Seat count in bench family |
Fri, Apr 25, 2014 at 1:14:44 PM
2012_need to add a fixed dimension setting to a family |
Wed, Dec 5, 2012 at 3:42:06 PM
Members: | 2097976 | Objects: | 23164 | Forum Posts: | 152289 | Job Listings: | 3 |
