Forums >> Revit Structure >> Technical Support >> 6"x48" Herringbone .pat revit file help
I am trying to write a .pat file for a 6"x48" herringbone pattern but I am having a lot of trouble and was wondering if anyone could help.
This is what I have so far:
*HerringBone 2x6, brick herringbone
;%TYPE=MODEL
45, 0, 0, 6, 6, 48, -24
135,
Not sure if this is right, but I have no clue how to get the 2nd and 3rd number in the second row. If someone could help, I would appreciate it.
Thanks!
Here you go:
45, 0, 0, 6, 6, 54, -42
135, 4.243, -4.243, 6, -6, 54, -42
Thanks so much! How did you know what numbers to write?
Take a look in the revit.pat file (C:\Program Files\Autodesk\<your revit version>\Data), at the beginning, there is an explanation/meaning of these numbers. Also, take a look at Tim’s pdf file here.
4" X 24 " orthogonal Herringbone Pattern .pat |
Sun, Oct 20, 2019 at 7:46:08 AM
6x12 Herringbone Pattern .pat file help |
Tue, May 1, 2018 at 8:05:17 PM
Import PAT File |
Tue, Dec 14, 2010 at 9:42:44 AM
help with .pat custom file. |
Mon, Oct 13, 2008 at 8:25:58 AM
How do i make an allternating horizontal 4" and 8" .pat file in notepad??? |
Tue, Sep 6, 2011 at 6:32:55 PM
Members: | 2101683 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
