93 Users Online (92 Members):
Forums >> Revit Building >> Technical Support >> Duplicate view
2 Posts No Rating |
I wanted to duplicate the floor plans and add some wall bracing details, So I hid everything not needed and just "Duplicated"
What I got was no ability to dimension on the new view and all my new notes went back to the original.
Help seems to be down.
Can someone explain the 3 Duplicate options?
THANKS!
2 Posts No Rating |
I need to take a somewhat blank slate (All dimensioms, ref planes and section markers hidden) and make a copy that I can dimension.
I have tried all 3 options and still not able to dimension.
I guess because they are hidden?
When you duplicate a plan, you have three options:
- Duplicate view ...( Is a full floor plane but only with model elements. All VG and view settings are the same.)
- Duplicate with detailing....( Same as above except with also with all annotative elements that are currently in the view.)
- Duplicate as a dependent....( Be careful here. Everything is depedent except for some annotative elements. Add or delete elements in one view and they are removed/added in the other.) This is a special view best used for match-line plans.
2 Posts No Rating |
Thank you very much WWHub!
Unable to duplicate a view |
Tue, Sep 13, 2011 at 6:44:21 PM
Duplicate elevation view |
Wed, Jan 11, 2006 at 4:41:27 AM
Creating duplicate views of elements |
Tue, Apr 24, 2012 at 5:57:37 AM
Duplicate views create duplicate callout tags in referring views... |
Fri, Mar 9, 2012 at 1:37:25 PM
Unable to Duplicate Schedule |
Wed, Sep 12, 2012 at 3:43:41 PM
Members: | 2017094 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
