Forums >> Revit Structure >> Technical Support >> Schedule/ Quantities
0 Posts No Rating |
1-Existing Quantity take off module in Revit automates location mark( Grids) for columns only. Though it is required for other elements like BEAM, Slab, Wall and Footings etc. (Civil work elements and related quantities)- Please refer attachments.
2- I want Cross Sectional Dimensions fields (e.g. LXB for Column and Beam perimeter in few cases) in schedule, which are not in field section.
Kindly Help.
Thanks,
Amit
0 Posts No Rating |
well , u need to make sure that this parameters u want to report in your schedule or sheet , that they are a (Shared parameters) , u can make this when u creating ur families entity before u start the project , or edit them by adding new (shared parameters) connecting them in a formula , to the column dimensions exsisting parameters......(check attatchment)
0 Posts No Rating |
Thanks hussie..
Your elaborated solution helped me for the 2nd problem.
Can you also look over the first problem where I am seeking location marks of other elements as like columns?
Thanks again,
Amit
How to include the Level parameter in Wall Schedule & quantities |
Mon, Sep 25, 2006 at 7:34:36 AM
CREATING A SCHEDULE FROM A GENERIC MODEL FAMILY? |
Mon, May 11, 2009 at 11:49:39 PM
schedule quantities by type |
Mon, Nov 17, 2008 at 9:45:50 AM
schedule quantities |
Wed, Dec 3, 2003 at 8:54:17 AM
Wall schedule |
Thu, Mar 22, 2012 at 10:55:00 AM
Members: | 2100485 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
