59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> detail component
Mon, Jul 13, 2015 at 11:22:58 PM | detail component
matrixwiz
im trying to find a way detail components of vinyl windows. there seems to be none that i can find any help? i need the head, jam and sill for section detail. or even if the actual componet window had those drawn in with it.
thanks
Tue, Jul 14, 2015 at 4:48:06 AM | detail component
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
There is quite a large range of PVC windows on the market and they each differ from country to country, climate to climate. You could contact your local supplier and try to get the details from them. It is likely though that they may only have them in dwg format like this website ( http://www.jeld-wen.com/professional/technical-documents/section-details ). In which case, you can download them yourself and import them into Revit and trace them in detail lines.
Embedded detail component scale issue
Mon, Oct 15, 2007 at 10:07:15 PM
Nested Annotation Family in a Detail Component
Fri, Mar 16, 2012 at 8:56:45 AM
CREATING DETAILS USING DETAIL COMPONENT
Mon, Jun 26, 2006 at 4:00:03 PM
Embedded Detail Component and Object Styles
Fri, Feb 12, 2010 at 3:21:25 PM
Cant exit detail component editting
Tue, Nov 19, 2013 at 3:28:47 PM
Page generation time: 0.4429
