83 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Export floor plan to format with transparent background
Mon, Jul 13, 2015 at 5:59:37 PM | Export floor plan to format with transparent background
LOSpistos
Hiii, Im having 4 plans L1-L4 which i want to overlay in photoshop so il create top view similar to site plan.because the model is really complicated with loads of cad and revit links i couldnt set up this site plan properly in revit. secondly i dont have time for it as deadline is tomorrow. Hah So i tried to export each plan into png and just simply place it in photoshop above each other. Unfortunately after insertinf png into photoshop the plans werent with transparent background. Is there any other way how to export the images into format with no background? Many thanks Luba
Mon, Jul 13, 2015 at 9:19:52 PM | Export floor plan to format with transparent background
CDWdavid
5 Stars: 5 Votes
See the post below, dated 9/18/2014 under Technical Support.
Tue, Jul 14, 2015 at 2:04:36 AM | Export floor plan to format with transparent background
LOSpistos
IT DOESNT WORK... aaaaaaaaah...i set up the plan to be the color scheme in background and when I export it into png its still with white background
Tue, Jul 14, 2015 at 2:42:23 AM | Export floor plan to format with transparent background
LOSpistos
aaah wait i find i found the solution
Tue, Jul 14, 2015 at 2:44:02 AM | Export floor plan to format with transparent background
LOSpistos
no i didnt.. Sad
Tue, Jul 14, 2015 at 1:52:25 PM | Export floor plan to format with transparent background
teeple1022
I have gotten it to work before.  I think you have to export as PDF without putting it onto a sheet
Wed, Jul 15, 2015 at 1:22:24 PM | Export floor plan to format with transparent background
teeple1022
CORRECTION: Print to pdf directly from drafting view.  Use current view (Not Visible portion of current window) Zoom 100% and Center.  Should have transparent backround when you bring it into photoshop.
Transparent Floor Plan when printing to PDF?
Fri, Apr 17, 2009 at 1:06:25 AM
Print to PDF with transparent background!
Tue, Jan 25, 2011 at 8:12:03 AM
REVIT 2015 - Underlay: EXPORT?
Tue, Aug 5, 2014 at 2:54:54 PM
3d Export Format
Thu, Nov 30, 2006 at 4:25:34 PM
PNG- TRANSPARENCY- COLOR SCHEME
Thu, Sep 18, 2014 at 12:47:19 PM
Page generation time: 2.2507
