33 Users Online (32 Members):
Forums >> Community >> Newbies >> Elevation Views from a separate project
Is there a method in which I can place an elevation view from a seperate project onto a sheet? I tried inserting views from file already and none of the views from the previous project showed up on the list to chose from.
Model views are not transferable between projects. You can link the project and cut a view that uses a linked view. But in this case, maybe exporting to CAD from the other project then linking or importing that CAD view may be what you want.
Good call I will try that. WWhub
Topography in elevation views |
Tue, Jun 20, 2006 at 1:44:12 PM
I can't see my Elevation View |
Thu, Dec 3, 2009 at 12:54:49 PM
any work around for this? transparent glass in shaded elevation views, revit 201 |
Mon, Jan 28, 2013 at 11:19:53 PM
using views in other revit projects |
Sun, Nov 21, 2010 at 2:23:26 PM
Rotating views to project north |
Mon, May 28, 2007 at 3:46:10 PM
Members: | 2017995 | Objects: | 22948 | Forum Posts: | 152217 | Job Listings: | 3 |
