Forums >> Revit Building >> Technical Support >> Need Help on Stringer
Hi guys,
I'm new here and this is my first post. Based on the attached image, is there a way to create that stringer in Revit? The one I created just goes straight to the top reference. I tried selecting the stringer while pressing the tab key, no luck. Would appreciate any help. Thanks in advance.
Regards,
jaiemm
Edited on: Thu, Jul 9, 2015 at 7:07:06 AM
Like the attached?
Stair by component. Use a landing for that last tread and delete the rear framing member after you create the landing.
Oh yeah, that's it! I'll give it try. Thanks for the quick response WWHub, Cheers!
Hi WWHub,
So, I was able to try what you have suggested and here's what I got (pls see image).
The one on the left is from a straight forward procedure based from your suggestion. The problem I have encountered is that I couldn't make the landing to have a similar profile as with the run (using non-monolithic landing type - "Same as Run" checked). If I try to uncheck the "Same as Run" option, entering a thickness is all there is. It doest have the option where one can load a profile.
Meanwhile, the one on the right is a multiple stairs. One is for the steps only and the other for the stringer with landing and railing. This time I tried unchecking the "Same as Run" option and entered a value of 1, the minimum value Revit allows for landing. As you can see there's a line that runs along the top-most step of the stairs.
I don't know if this is ok to have multiple stairs but it's the only way I found to model the required stairs for my current project.
If you have other idea, please I would like to know. Others can also chime in. Thanks!
Change your landing settings. You can adjust where the framing is in relation to the surface.
Stringer Haunch (level off) at top of flight |
Wed, Dec 14, 2011 at 2:03:06 PM
Stair Stringer Question |
Fri, Jul 28, 2017 at 4:01:08 PM
middle stringer on landing |
Tue, May 27, 2014 at 9:30:49 AM
Stringer Issue |
Fri, Jan 3, 2014 at 4:45:42 AM
Stringer in Stair by Run: Problem with offset |
Tue, May 6, 2014 at 7:44:18 PM
Members: | 2116465 | Objects: | 23196 | Forum Posts: | 152303 | Job Listings: | 3 |
