62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> Delete old imported cad drawings
We work with Revit 2015.
Now i've upgraded an old drawing from revit 2013.
I can't select and delete old imprted cad drawings which are imported on a selected level.
The same thing happens with old reference planes and grids.
We've downloaded and installed all revit building suite updates.
Can someone please tell us how to remove these things ?
Make sure your process is correct.
Can you select the import? If not, are you using design options?
Are you sure it is not linked? Read THIS.
Check and see if the grids/RP are pinned.
I can't select the import, there are no design options in this project, and they're not linked...
The grids/RP are not pinned.
Revit only detects the imported cad drawings when i draw a line, it makes an intersection.
Sometimes upgrades are corrupted. In that case, you need to send to Autodesk. This is when subscription pays for itself.
i will try that, thanks.
Thanks i do not know how to reload it ! about imported categories what i want is not hiding it, i want to make it as i am not imported it because when you delete the imported category(Cad) and go to tab of imported families you will see layers and everything is exsiting there (it is like want to be sure that linked deleted file is not live inside revit anymore )
Thanks,
Sd-Academy
Delete imported categories |
Tue, May 23, 2017 at 10:26:44 AM
Imported CAD drawings - editing in Revit |
Sun, May 18, 2008 at 7:45:38 AM
REMOVING CAD IMPORTS IN REVIT MEP 2011 AFTER DELETING |
Thu, Sep 9, 2010 at 10:23:27 AM
Remove hidden CAD imports |
Thu, Nov 6, 2008 at 9:32:16 AM
Imported CAD formats appearing halftone |
Thu, Oct 18, 2007 at 1:44:50 PM
Members: | 2042240 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
