21 Users Online (20 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Parametric Custom Portal Frame - please help $offered
Tue, Jul 7, 2015 at 8:44:02 PM | Parametric Custom Portal Frame - please help $offered
markenderwick
Hi All,
i am looking for either some help, or if someone is willing to model this (and i will pay them).
i need to model up a portal frame of something we call "steltech" in NZ. it is essentially a tapered leg (straight on the outside) and then a series of tapered rafters.
the span of this is 60m, knee depth 1550mm. I have a 2d cad plan of the layout and info on all of the flanges and webs. I have tried setting up a parametric family with sweeps and extrusions, but to be honest my experience in this type of family creation is limited.
attached a screen grab of a simplistic one the architect has generated (i have tried editing / getting inspiration from theirs, no luck).
i would like to able to re-use the family for other sheds etc, so need to able to adjust knee depth, span, height, pitch etc.
thanks in advance,
Mark
Mark EnderwickEnderwick Design -NZ
Wed, Jul 8, 2015 at 6:45:23 AM | Parametric Custom Portal Frame - please help $offered
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Have you looked at some of the families that are avaliable here?
http://www.revitcity.com/downloads.php?action=view&object_id=3695
http://www.revitcity.com/downloads.php?action=view&object_id=3730
Wed, Jul 8, 2015 at 4:12:09 PM | Parametric Custom Portal Frame - please help $offered
markenderwick
Thanks for the message and link, have downloaded and theres certainly some themes in there i will try and use to model the frame.
my offer still stands if anyone thinks they could model this..
Cheers
Tue, Sep 22, 2015 at 7:30:30 PM | Parametric Custom Portal Frame - please help $offered
tomoki06
Hi Mark
I just spent few hours this morning and built a fully parametric Steltech portal frame.
You can change your pitch, beam depths, knee heights and other parameters.
Let me know if you are interested.
Regards,
Thomas
UK - looking for a parametric steel portal frame for a factory unit!
Tue, Apr 19, 2005 at 11:06:43 AM
portal frame
Thu, Aug 6, 2009 at 8:41:32 PM
Help required with portal frame buildings
Mon, May 9, 2005 at 1:27:29 AM
Portal Frames
Mon, Jun 19, 2006 at 2:10:53 PM
Control Position of Door Frame/Panel in Wall Thicker Than Door Frame
Thu, May 6, 2010 at 7:29:41 AM
Page generation time: 0.3343
