Forums >> Revit Building >> Technical Support >> Dot Region Pattern
3 Posts No Rating |
Hi all,
i want to make a region fill pattern that is the same as the dot hatch in revit. (Evenly spaced dots)
I found this online, but I don't know where or how to create custom hatches in revit.
Revit structure 2016
3 Posts No Rating |
Same as the dot hatch in autocad* sorry
3 Posts No Rating |
This is what I found, what do I do with it?
OTS,A series of dots;%TYPE=MODEL0, 0, 0, 0.79375, 1.5875, 0, -1.5875
3 Posts No Rating |
So I added this as a .pat file, but there is nothing in the region
3 Posts No Rating |
Okay so, after a figured out who to make these crazy things. I made two for your guys to use.
I don't know if there is a way to scale the region once it is in revit, like you can do in CAD, so I made two, one is half of the other.
OTS,
;%TYPE=DRAFTING
90, 0,0, 0,.25, 0.0,-.25
90, .125,.125, 0,.25, 0.0,-.25
OTS,
;%TYPE=DRAFTING
90, 0,0, 0,.125, 0.0,-.125
90, .0625,.0625, 0,.125, 0.0,-.125
You can scale while loading the pattern to Revit.
Be aware that "dots" will be converted on loading to very short lines consistent with Revit's minimum line length.
Zoom right in to gauge the effect.
Hugh Adamson
www.hatchkit.com.au |
0 Posts No Rating |
Hi JTebok,
why am I not able to import it in revit? Says No "Drafting"type patterns found.
Thanks.
Check that there are no leading spaces on lines within the.PAT file.
Hugh Adamson
Must be saved in a simple txt format with the PAT extension.
dot pattern for hatch |
Thu, Jul 17, 2014 at 7:59:18 AM
Howdy! I'm new! |
Wed, Apr 14, 2010 at 1:29:56 PM
filled region pattern color changes when drawing scale changes |
Thu, Apr 14, 2016 at 7:32:06 AM
Blank filled Region |
Fri, May 2, 2008 at 12:30:12 AM
Site Sub Region Surface Pattern |
Thu, May 7, 2009 at 1:23:33 PM
Members: | 2056043 | Objects: | 23069 | Forum Posts: | 152281 | Job Listings: | 3 |
