84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Filtering by Phases - Revit MEP 2015
Thu, Jul 2, 2015 at 8:05:09 AM | Filtering by Phases - Revit MEP 2015
jmckee
We have a renovation project with roughly 8 Phases of construction. The client wants to see a full buildout with the phases filled in by color or different line types per phase. Is there a way to create filters through the visibility graphics that can filter by phase? I assume that I could then use the overrides in the visibility graphics to change the color or line type.
Thu, Jul 2, 2015 at 8:20:01 AM | Filtering by Phases - Revit MEP 2015
Revit's phases are hard for new users to understand because they are NOT project phases.
Revit's phases are really only new, temporary, demolished and existing based on the current's view phase setting.  Revit's phases are really view phases.  So If you have set up 8 phases and the view is set to phase 6, then phase 6 is new and phases 1,2,3,4,5 are all existing.
If you have noticed, view filters do not allow you to filter by phase, so what do you do?
So in your case, I suggest you add to all your compontents (maybe just everything) a new project parameter - shared - and maybe call it PROJECT PHASE.   Now you have something to view filter by and change the VG accordingly.
BTW - You will have to fill in this parameter for all objects - nothing automatic here.
Edited on: Thu, Jul 2, 2015 at 8:21:02 AM
Thu, Jul 2, 2015 at 8:37:31 AM | Filtering by Phases - Revit MEP 2015
jmckee
Thanks WWHUb. I guess my question should be refined a bit. Is there a way to set up filters that use the phase created parameter in the properties to accomplish this instead of creating a new project parameter?
Thu, Jul 2, 2015 at 9:06:08 AM | Filtering by Phases - Revit MEP 2015
I answered that question!   IT IS NO!
Phases and Worksets - Revit 2012
Fri, Aug 2, 2013 at 8:15:14 AM
Schedules - filtering by view or duplicate?
Mon, Jul 28, 2014 at 8:24:36 AM
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:49 AM
Showing multiple phases in one viewport
Tue, Jun 16, 2009 at 8:02:56 PM
Filtering in Schedules
Mon, Feb 4, 2019 at 11:41:17 AM
Page generation time: 2.1051
