114 Users Online (113 Members):
Forums >> Revit Building >> Technical Support >> AutoCAD imports are no longer showing up in every single view like they used to
14 Posts No Rating |
I have checked my visibility settings and everything that is turned off or hidden or object styles and everything but for some reason when I import into Revit 2014 (link actually) the AutoCAD files are not showing as a part of the file anymore when I go to any other view that is not the one I imported it into. What is happening? I need to access the AutoCAD from different views to move it up higher since it won't let me change the level or view it in another level that I linked it to
Was it linked "This view only"?
Was it linked in a workset?
I now have found that it was this view only. I have never set that before but for some reason it is now the default. Is their a way to make it viewable in all views after making it only viewable in the 1?
Autocad imports PDF's. Is there anyway Revit does that? |
Mon, Feb 1, 2010 at 5:06:18 PM
orientation of imports |
Tue, Apr 27, 2010 at 8:30:15 AM
Autocad Import Problems |
Tue, May 5, 2009 at 1:55:33 PM
Dual View Reference with Single Call-out |
Tue, Mar 8, 2016 at 2:29:34 PM
Autocad details with hatch showing as black/solid |
Wed, May 22, 2013 at 11:47:29 AM
Members: | 2042348 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
