51 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> Component visibility in elevations
1 Posts No Rating |
Probably something simple, but I can not spot the problem.
I inserted a wall pack light on the East Elevation of a model, works just fine. Went to insert the same wall pack on the South Elevation and Revit reports that none of the components will be visible. Even more annoying, if I switch back to the East Elevation, the wall pack on the south side is visible.
Any ideas what I'm missing? Using Revit 2015.
Thanks,
David
Compare your VG settings and also your view's discipline in these two views.
Visibility of downloaded component |
Wed, Jun 5, 2013 at 3:49:42 PM
component visibility in different plan views |
Wed, Sep 19, 2007 at 10:44:53 AM
REVIT CONTENT - problem with velux family |
Wed, Nov 10, 2010 at 5:22:23 AM
Datum Extent Visibility |
Mon, Nov 12, 2007 at 3:28:18 PM
Visibility of component acting up |
Wed, May 7, 2008 at 4:59:08 PM
Members: | 2017305 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
