Forums >> Revit Building >> Technical Support >> A fatal error loading family into project overwriting existing
0 Posts No Rating |
I'm learning families, I dont know what happend, when I do some changes to the family (e.g. changing default height)
and then trying to load to the project and overwrite it version and parameters, I get fatal error...
Pls chesk attached file. Lodad family into project, then go back to family, make some changes and reload it, does it crashes?
P.s. Revit Architecture 2015. Its first time when I get error.
Edited on: Sat, Jun 20, 2015 at 12:59:44 PM
I’m sorry, but I cannot recreate your issue. It’s all good here …well, almost. Just left handle is left behind when depth is changed. Other than that I couldn’t find any problems.
0 Posts No Rating |
hm, thanks for help man, now I guess this problem is due tu software problems... Ill try to reinstall Revit
fatal error |
Wed, Aug 30, 2006 at 1:15:23 PM
Fatal error on a shared job Revit 2015 |
Tue, Mar 15, 2016 at 1:06:33 AM
Fatal error when in any type of sketch mode |
Wed, May 16, 2018 at 11:28:44 AM
Fatal Error when adding casework tag |
Mon, Apr 6, 2009 at 12:38:41 PM
Overwriting an element |
Wed, Apr 5, 2006 at 2:49:25 AM
Members: | 2099198 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
