43 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Joining Walls to Floor
Thu, Jun 18, 2015 at 7:08:10 PM | Joining Walls to Floor
mrpaulrich
I've been working of this project where I have both exteior and interior walls that continues down to foundation, however, once i draw the floor, it does not show that bottom edge of wall where it cuts through the floor. See attached photo.
It is really bugging me and causing a problem with accuracy. How can I correct this?
Thu, Jun 18, 2015 at 8:36:23 PM | Joining Walls to Floor
ronmalit
5 Stars: 3 Votes
basically, revit is a BIM tool, so how you want to construct it , is how you should model it. what i mean is, if the wall goes down to your foundation, therefore you need to edit your floor and create the opening for it.
however if you just want to view floor's bottom edge.. just use JOIN command.
thanks
** dont be mad, i dont have much... i am homeless
floor and wall joining and finish material
Fri, Oct 25, 2013 at 1:35:18 PM
highrise towers slabs-walls joining
Tue, Jun 1, 2004 at 6:18:09 PM
Extending Wall finishes/Walls not joining
Wed, Dec 3, 2008 at 12:13:37 PM
Room Tags and Detached Walls
Tue, Sep 12, 2006 at 12:00:07 AM
Joining Walls at Awkward Angles
Tue, Mar 11, 2014 at 8:31:13 AM
Page generation time: 10.7004
