74 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Kitchen hob not showing in plan view
Wed, Jun 17, 2015 at 4:27:46 PM | Kitchen hob not showing in plan view
FranBerenguer
Hi there, I am using Revit 2015. I am making the equipment for the kitchen with the default revit families. The problem is, when I put the kitchen hob over the counter top, it doesn´t show in the floor plan. I have even tried with the countertop with a whole, but still doesn´t show. The thing is, when I offset the hob 100 mm it appears in the floorplan, so I don't think it is related to the view range, also, the sink shows perfectly in the floor plan. I attach 3 pictures so you can have a better idea of the issue.
Many thanks.
Thu, Jun 18, 2015 at 6:55:08 AM | Kitchen hob not showing in plan view
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
A few possible issues
1) Open the hob in the family editor and check the visibility allows it to show the 3D parts in plan.
2) In the Revit model open a 3D view and take a look at it. Is it in the right position and the right height above the ground.
3) Check your visibility settings in plan to ensure the family category is turned on. (VV)
4) Cut a section through it and check its height is correct and that there is nothing that would obscure it.
5) In your plan view - properties - check the View Range is set such that you will see it.
6) Is anything turned off that would obscure it?
that should get you started.....
B.
Strange Gas Hob Component
Thu, Apr 23, 2009 at 6:09:57 AM
Office furniture not showing through counter
Mon, Sep 30, 2013 at 6:12:15 AM
Roof Plan not Showing in Site Plan
Wed, Jul 12, 2017 at 12:03:32 PM
11
I need this kitchen island i found rezied to fit in the kitchen..help plz
Wed, Oct 8, 2008 at 2:32:36 PM
Solid Forms
Thu, Nov 10, 2005 at 2:02:59 AM
Page generation time: 1.3778
