23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revision Numbering
Wed, Jun 17, 2015 at 11:53:34 AM | Revision Numbering
joekozelka
Hello
Dose anyone know how to change the numbering system so that the schedule may follor a sequence other than A, B, C, ... or 1, 2, 3,... in particular we need something like C01, C02, C03... to maintain our office standards.
Please Help
Wed, Jun 17, 2015 at 12:26:51 PM | Revision Numbering
joenunez
Revit will start you with those number styles (A,B,C, etc) but you can click on annotation or modify value in Properites Window to match your standards. By modifying the value in your Properties window or instance element with C01, Revit will make the succeeding number C02, C03, etc.
joenunez
Revit Architecture 2017 \
20170225_1515(x64)
Windows 7 Enterprise SP1 \ Xeon \ 20 GB RAM
Wed, Jun 17, 2015 at 12:39:25 PM | Revision Numbering
joenunez
Apologies...I just reread your subject, you were interested in customizing your Revision Numbers. I believe I gave you a method for customizing numbering for other annotative elements (grids, doors, etc). To do what you are interested in doing, you might want to follow the tip from Veng Leong as documented from her blog here:
http://revit.rayvinly.com/customize-revision-number/
joenunez
20170225_1515(x64)
Thu, Jun 18, 2015 at 2:33:42 AM | Revision Numbering
joekozelka
 The last Practice that I had worked for had the same problem with the numbering of revisions to office standards.
Thank You, that link was very helpful and answered my question.
Revision Numbering
Wed, Dec 12, 2012 at 1:11:16 PM
Revision with None Numbering
Mon, Sep 23, 2013 at 3:29:50 PM
Customizing Revision Sequence Numbering
Wed, Aug 5, 2009 at 9:51:49 AM
Revision Number for sheet issued for the first time [ 1 2 ]
Tue, Oct 15, 2013 at 10:05:02 AM
19
Creating Sketch Sheets and linking revision tags to Original sheet...
Fri, Jul 14, 2017 at 11:16:32 AM
14
Page generation time: 0.2019
