74 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> Moving Design Options Elements Back To Main Model
9 Posts No Rating |
I am trying to take certain elements that were placed in a design option and move them back to the main model. Am I missing something or is this not possible? I've searched for solutions in the Help manual with no luck and have not found anything useful online thus far.
joenunez
Revit Architecture 2017 \
20170225_1515(x64)
Windows 7 Enterprise SP1 \ Xeon \ 20 GB RAM |
If it is the whole design option, then just accept it and everything will move back to the main.
If it is a large portion, then the above might still be best then move into a new DO those things you don't want.
If it is a small portion, you will have to copy to clipboard, then switch to the main model and paste.
9 Posts No Rating |
Interesting. So it looks like copying to clipboard will have to do. It seems like Revit should have this feature built-in to the Design Options dialog window. Thanks.
joenunez
20170225_1515(x64)
I forgot to say that you will also want to remove the item from the option after you copy/paste.
I will correct part of my first response.... If you accept one design option from a design option set, all of the other options will be deleted so pay attention.
Cleaning Up Design Option Elements with Main Model Elements |
Wed, Jun 17, 2015 at 1:38:27 PM
shortcut for "main model" of Design Options |
Thu, Sep 26, 2013 at 4:47:16 PM
REMOVING Design Options |
Mon, Jun 30, 2008 at 11:58:41 AM
Design options and topography |
Thu, Dec 2, 2010 at 12:56:10 PM
Design Options issue |
Thu, Jun 16, 2005 at 9:00:05 AM
Members: | 2030542 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
