70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> walkthough elevations
Sat, Mar 25, 2006 at 10:05:49 AM | walkthough elevations
hammer87
hammer87 Avatar
3 Stars: 4 Votes
i wanted to know if in a walkthough if you could make it so you go up and down staris, etc
Tue, Mar 28, 2006 at 8:10:29 PM | RE: walkthough elevations
fordd
actually you can, and it's much easier than you'd think as you drag your camera thru your building and you get about half way up your stairs change the "From" level to the next level up or down and continue dragging your camera. It's very cool Smile
Wed, Mar 29, 2006 at 2:17:23 PM | RE: walkthough elevations
hammer87
hammer87 Avatar
3 Stars: 4 Votes
wow that is pretty easy
Wed, Mar 29, 2006 at 5:12:05 PM | RE: walkthough elevations
geoffy
Another way you can do it is to use the "show camera" function in an elevation view and move your key frame/s up to where you need them. Don't forget that you can also pan the camera at each key frame whilst still moving along the frame path which will give you a really nice look also. Hope this helps
AutoCAD & Revit TAFE teacher from regional Australia
Walkthough decal
Thu, Jan 14, 2010 at 1:48:56 PM
walkthough
Thu, Mar 19, 2009 at 8:04:02 AM
Problem with Interior elevations
Fri, Feb 13, 2015 at 1:51:29 PM
Walkthough question. I'm sure an easy question to answer!
Sat, May 3, 2008 at 10:50:14 AM
how to add elevations to door & window schedules
Tue, Oct 30, 2007 at 11:59:24 AM
Page generation time: 0.7007
