58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> 'Draft' stamp in title block won't show
Fri, Jun 12, 2015 at 6:10:34 AM | 'Draft' stamp in title block won't show
geraldrogers
I have a title block with a red 'draft' stamp (it is a label with on/off capability) however when I set up a drawing sheet and turn it on it doesn't appear. There are border lines to the title block which seem to be set up the same way and these work fine (you can turn them on or off). When I open a finished sheet with drawing and title block and click on the title block (so it is highlighted in blue) and turn on the draft stamp a blue '?' appears where the stamp should be. But when I click back out of the title block the 'draft' stamp does not show. Any ideas?
Gerald Rogers
Revit 2015
Fri, Jun 12, 2015 at 6:55:21 AM | 'Draft' stamp in title block won't show
What is your draft stamp?  Ours is a seperate annotation family nested in our titleblock family with a visibility y/n parameter.
Printing without title block and to 1"=100'
Thu, Dec 8, 2005 at 4:58:40 PM
View Title scale text won't show
Tue, Dec 29, 2009 at 2:36:52 PM
Changing paramaters of 'Title with line'
Wed, Sep 20, 2006 at 9:47:19 PM
Elevation won't show in preview and can't be printed out
Fri, Nov 20, 2015 at 10:59:00 AM
Structural beam won't show in elevation
Fri, Aug 12, 2005 at 5:22:09 PM
Page generation time: 2.0552
