Forums >> Revit Structure >> Technical Support >> frosted glass with image cutout
2 Posts No Rating |
I've tried doing a frosted glass door with a transparent image cutout of it using cutout in the material, but when i render it the image is also cutout of the reverse face of the glass sheet so i get two mirrored cutouts overlapping - how do i get rid of this?
Edited on: Fri, Jun 12, 2015 at 5:49:22 AM
I have the same problem. Has this been resolved?
2 Posts No Rating |
I modelled the manifestation as a thin film separate from the glass in the door family with a plastic material with an image transparency painted to 1 face only of the film in the family
I'm still not sure here, even putting a "Thin" film seperate to glass, I still get the image mapped to both sides of the film. What am I missing? painted to 1 face only in family? how do I do this? I must admit families are not mt forte.
Thanks in advance.
2 Posts No Rating |
The glass door should have a normal glass material, I gave the film a glass material but then used the "paint material to face command" (see attached image), in the family editor (this command is also available in the main revit project editor) to paint the manifestation material to one face only of the film.
Hope this helps
2 Posts No Rating |
did that work for you ?
How to change glass wall to a frosted design? |
Wed, Dec 15, 2010 at 5:52:33 PM
frosted glass |
Wed, Jul 11, 2007 at 10:01:28 AM
I need a frosted glass material |
Tue, Aug 5, 2008 at 10:48:40 AM
Decal Cutout Image |
Tue, Sep 9, 2008 at 2:53:13 PM
curtain panel glass type |
Sun, May 30, 2010 at 6:05:39 AM
Members: | 2115609 | Objects: | 23192 | Forum Posts: | 152303 | Job Listings: | 3 |
