43 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> 3D Fascia Board Help
Thu, Jun 11, 2015 at 6:21:34 AM | 3D Fascia Board Help
jamesm2505
Is there any way to create a fascia board with a repeating 3D pattern on it or will this require manually creating extrusions/voids?
I have attached a picture of the profile I need to create.
Thanks
Thu, Jun 11, 2015 at 7:35:02 AM | 3D Fascia Board Help
When a facia is created with the roof fascia tool, it is just a sweep.  Obviously a profile can not undulate like you want.   You can create a face based void to cut your fascia or you could use a line driven family to place a repeating solid as a positive rather than a negative.
Thu, Jun 11, 2015 at 7:58:03 AM | 3D Fascia Board Help
jamesm2505
Thanks WWHub, ive gone for a repeating solid along the section, which was less hassle than I expected. Out of interest is there any way to create a family that behaves like a sweep? i.e place a repeating component along a defined path, or is the array tool the best bet?
Thu, Jun 11, 2015 at 8:47:41 AM | 3D Fascia Board Help
The array - be it in a line based family or directly in the project, is the only way I know.
Fascia Board Too Long
Tue, Nov 20, 2012 at 10:19:31 AM
Custom barge board/ fascia end profile
Mon, Oct 15, 2012 at 3:14:42 PM
12
fascia on two different sloped roofs
Thu, May 28, 2009 at 1:01:04 PM
Cut Fascia by roof
Mon, Jun 25, 2012 at 10:39:49 AM
Can't get fascia heights to match
Thu, May 19, 2011 at 4:57:15 PM
Page generation time: 0.5843
