41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> The Story of the Magic Invisible wall - a Revit Bug v2014
Wed, Jun 10, 2015 at 6:46:41 PM | The Story of the Magic Invisible wall - a Revit Bug v2014
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
I have created some furring walls adjacent to curtainwall that has a curb wall as the bottom panel. I adjusted the curtain wall out a little bit and when I went to move the furred wall it dissapears! Like Magic! What's weird is that it is still there and I can select it. It's in the correct phase, workset, level, type, no overrides, no filters, no visibility issue, no weird wall joins, no location line issue, no funny business, just invisible in this one instance. So I'm pretty sure this is some kind of a bug, but I'm hoping there's a possibility someone has encountered this illusion and knows the Revit magician's secret to making it re-appear. Abracadabra!
139690_20150610-Wall_Bug01.PNG139690_20150610-Wall_Bug02.PNG139690_20150610-Wall_Bug03.PNG139690_20150610-Wall_Bug04.PNG
Thu, Jun 11, 2015 at 7:31:24 AM | The Story of the Magic Invisible wall - a Revit Bug v2014
Change your curtain wall setting by unchecking the 'automatically embed' and your wall will come back.
Thu, Jun 11, 2015 at 10:48:01 AM | The Story of the Magic Invisible wall - a Revit Bug v2014
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Unfortunately, that did not work. This wall is actually unrelated to the curtain wall. It's just beside it. Plus, it's only in that location. Recreating the wall has not affect either. I'm hoping I don't have to delete the curtain wall and start over just to fix the bug, but it's looking like I'll have to do that. Thanks for the suggestion.
Thu, Jun 11, 2015 at 10:52:40 AM | The Story of the Magic Invisible wall - a Revit Bug v2014
I've been using 2014 for a long time and I don't believe there is any kind of bug like you suggest. Either there is a user error here or there is a corruption.
Copy the curtain wall and you wall to clipboard and paste into a new project.  If the problem still exists in that project, purge all 3 times and post the project so we can look at it.
Thu, Jun 11, 2015 at 11:07:37 AM | The Story of the Magic Invisible wall - a Revit Bug v2014
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Wouldn't a corrupted element technically be a bug? How it gets corrupted and the the corrupting elements are bugs in my mind. There's definitely other stuff like that with curtain walls. Little glitchy things that happen especially with mullion joins, curtain grids and panels. They're finicky for sure especially if you are doing complex systems within curtain walls. Thanks again for your suggestions.
Mon, Jun 15, 2015 at 9:27:48 AM | The Story of the Magic Invisible wall - a Revit Bug v2014
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Cae and Point. There seems to be an unsaid limitation to the proximity to vertical curtain grids and adjacent joins. This is happening more and more frequently. This is a bug. A glitch. Snafu. Goof. Oops!
Mon, Jun 15, 2015 at 10:13:13 AM | The Story of the Magic Invisible wall - a Revit Bug v2014
You don't point out what you see in that image.  I Think I see a CW corner but not sure what all is there.
Curtain wall intersections at corners take special attention.  In most cases, I turn off joins and manually control the CW.  Butt glazed CW will NEVER miter at a corner.  You can T the CW's here and by controlling grid location and using an empty system panel, you can create what you need in the corner.
BTW - Corrupted files can be bugs but in most cases, the file is corrupted by system malfunction. << Doesn't happen very often either way once the edition has been out long enough for a couple of updates.
I would still like to see that file that you post an image of in the beginning.
Fri, Jun 19, 2015 at 8:53:53 AM | The Story of the Magic Invisible wall - a Revit Bug v2014
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
I understand that the glass will not mitre. Here's the condition (attached) Iknow what you mean about using the empty curtain panels to avoid the grid situation. I've had to do that in other instances. I'm curious about what you said about system based bug rather than Revit based. That may help explain some other things. Let me know what insight you have on this and see what I'm missing. Thanks for taking a look.
Fri, Jun 19, 2015 at 10:47:34 AM | The Story of the Magic Invisible wall - a Revit Bug v2014
I always find it interesting to look at other users processes because I can learn new things.  In your case though, I'm lost.
I find it somewhat strange that you chose to place a wall as a curtain panel for your curb. Obviously you can do this but I would have just run a wall.
I can't figure out how you got this CW panel (the curb) to extend beyond the limits of the CW.  (See Image)
Is this the wall that you were having problems with or should there be your furred wall too?
It appears that joins are always turned on for a wall used as a panel even if the CW is set not to join. << That could be the cause of your problem.
Fri, Jun 19, 2015 at 2:08:32 PM | The Story of the Magic Invisible wall - a Revit Bug v2014
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
I thought about placing another wall under the curtain wall, but I found it may present some other disadvantages when trying to coordinate all of the elements that want to move together - all one object is strategically useful. Based on other conditions in the project, I'm not convinced that the wall as panel is presenting the entire issue, though if these panels are replaced it behaves. That's why I was thinking it was buggy because once the element is challenged to do a little bit more work, though allowed, it gets challenged and fails to provide the correct solution, i.e. joining the mullion correctly. It's just being kind of weird here. I gave up on the furred wall situation for now since I've exhausted all my options.
REVIT 2011 BUG OR NOT BUG?
Mon, Dec 6, 2010 at 6:28:30 PM
Extending an exterior finish on a wall
Mon, Mar 6, 2006 at 5:38:23 PM
Quick boundary select/Magic wand?
Tue, Feb 17, 2009 at 8:58:49 AM
1 1/2 story house
Mon, Mar 10, 2014 at 6:59:21 PM
Cannot figure out how to copy a wall section up to next story?
Sun, Oct 13, 2013 at 7:57:01 AM
Page generation time: 8.2614
