133 Users Online (131 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> beam - how to show overhead? single line
Tue, Jun 9, 2015 at 6:46:13 PM | beam - how to show overhead? single line
KennedyDrafting
Hello.  Newbie (first post!), REVIT 2016.
What's a smart way to get an overhead beam to show on the floor plan - graphically represented by one line in the center of the beam?
Most responses to similar questions say to use line work.  While that is parametric, I have only been able to get it to show TWO lines and not one.
I can use a detail line to represent the beam with one line but, it's not parametric.
File attached that might illustrate my question better
Thank you,
JAK
Kennedy Drafting
Tue, Jun 9, 2015 at 10:50:55 PM | beam - how to show overhead? single line
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
In the beam family, add a symbolic line in the center of the beam. In the project, set view underlay to the current level and RCP underlay orientation. The beam should be visible now. Set visual style to wireframe. You should be able to pick the center line of the beam with the linework tool. Set underlay to none and visual style back to hidden lines.
Wed, Jun 10, 2015 at 9:52:25 AM | beam - how to show overhead? single line
KennedyDrafting
pijpiwo - perfect.  exactly what I needed.  Thanks!
Single line building line for site plan
Mon, Aug 17, 2015 at 8:15:57 PM
Beam Systems
Wed, Aug 13, 2008 at 11:42:00 AM
Beam & Beam systems
Tue, Oct 21, 2008 at 4:36:54 PM
beam revit family
Fri, Sep 10, 2010 at 12:33:42 PM
Revit Beam for Reinforced Concete works
Sun, Jun 15, 2008 at 1:05:31 PM
Page generation time: 2.9560
