Forums >> Revit Building >> Technical Support >> How do I change the top rail profile in Revit 2015?
I've been trying to do this for awhile. Ive tried the base railing edit type window, but the "type" dropdown in the "top rail" section only gives me the options of "none" or "top rail type". I guess what Im asking is how do I change the properties (and profile) of the "top rail type" that is in the dropdown?
Look in your HELP: http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-C6FFE400-6A6C-4241-8D9F-56690C9B7CB1
Hover to top rail, press tab until top rail is selected, unpin, then in properties press edit type. You can find your loaded profile there. If anybody find it useful, reply.
Everything u can do in propeeries.
it will tell u which profile it used.
then search for that name in project browser.
than make it save as, and create new profile, then load to project.
then u will have option to select it
here u will get loaded profile deatails. find screen shot(it is type properties of handrail)
2015 use baluster per tread on stair (with no top rail?) |
Thu, Sep 3, 2015 at 4:50:58 PM
2015 Custom Top Rail Profile doesn't Show in Drop Down?? |
Wed, Dec 16, 2015 at 3:43:41 PM
Baluster Top Offset Issue |
Tue, Jan 12, 2016 at 8:43:41 AM
Top rail offset |
Wed, Jun 21, 2017 at 11:14:52 AM
Rail Top Rail vs Handrail 1 |
Tue, Nov 26, 2013 at 9:58:50 AM
Members: | 2098956 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
