40 Users Online (39 Members):
Forums >> Revit Building >> Technical Support >> Curtain wall
Hi I have the same problem with this curtain wall please Help me ..
what happens is that by placing the horizontally .. mullion separates the panel..y need to be continued as shown in the second image
http://taller-revit.forosactivos.net/t1503-sloped-glazing-roof
No second image and if you do post - mark it up to describe your problem. DON'T EXPECT US TO GUESS!
![rbcameron2 Avatar](user_avatar/78200.jpg)
![4 Stars: 25 Votes](/images/stars_4.gif) |
A couple of things here:
A) if your curtain wall has pre-determined spacing, then you can click on the curtain GRID. Not mullion, not panel. and then the ribbon up at the top will give you the option to "remove" a grid.
B) when you go to make a curtain wall and you are creating custom spaces, then when you make your curtain wall as a single panel, use the add grid, then choose "all but selected" and create your spacing and add staggers as required.
Is this what you were asking for?
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here |
hi i dont explain very well.
the problem is when i create a mullion in curtain wall, its separete the panel. and ineed to be continuos..
the second image is bellow
Edited on: Mon, Jun 8, 2015 at 4:19:53 PM
Edited on: Mon, Jun 8, 2015 at 4:20:23 PM
Edited on: Mon, Jun 8, 2015 at 4:21:41 PM
Curtain Wall Panel to Curtain Wall Door |
Curtain wall not cutting through moulding |
Thu, Oct 22, 2015 at 2:53:44 PM
Splitting a curtain wall to change the type of wall it is |
Thu, Aug 6, 2009 at 12:46:42 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed |
Thu, Jan 24, 2013 at 8:06:06 PM
curtain wall |
Sat, Jan 10, 2009 at 10:01:35 AM
Members: | 2022243 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
