31 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Railing Extensions
Fri, Jun 5, 2015 at 10:08:58 AM | Railing Extensions
jsego
Hello,
I am using Revit 2014.  I am trying to edit a rail extension.  I have placed these raillings on a host and offset the balusters to be 3" away from the face of the treads.  I need the handrail to stop at the balusters.  If I edit the path of the rail to start and end where I need it to, it changes the slope of the rail.  How can I get my rail to look like the attached?  I'm sure this is an easy fix but I can't get it to work.
Thanks.
Fri, Jun 5, 2015 at 10:13:56 AM | Railing Extensions
You have only two ballusters - correct?   Define as end posts instead.  To have the handrail end at the outside face of the post instead of the middle, change the post space + or - as appropriate.
Fri, Jun 5, 2015 at 10:20:39 AM | Railing Extensions
jsego
Yes I only have two balusters.  How do I define them as end posts?  Thanks!
Fri, Jun 5, 2015 at 10:31:33 AM | Railing Extensions
You can't learn if you don't at least try.....
From your HELP: http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-BC7FE8C5-6515-4760-875D-2921CA834DF6
Handrail Extensions in 2013 - Where is it?
Sun, Jul 12, 2015 at 11:54:19 PM
Stair Handrail Extensions
Fri, Apr 11, 2008 at 10:48:32 AM
Steel Pipe Railing
Fri, Mar 31, 2017 at 10:35:44 PM
horizontal extension to the handrail
Wed, Jan 9, 2008 at 1:25:32 PM
Revit Extensions Tuitorial
Wed, Oct 14, 2009 at 8:58:22 PM
Page generation time: 1.8149
