84 Users Online (83 Members):
Forums >> Revit Building >> Technical Support >> custom window family
Can anyone explain to me why this family won't load into a project? Have tried to keep it as simple as possible but it keeps coming up with a 'can't make type' error.
using revit architecture 2015
thanks
I didn't look at the family but quite often, this is a wall thickness issue. Does the window work in a thinner wall? Change the wall thickness in the family to something closer to your project's wall thickness.
I tried that earlier, and the wall thickness is exactly the same as the one in the project.
It comes up with the 'can't make type' error before even attempting to place it on a wall, it happens as soon as i load it into the project or any time i select it in the drop down list
There is something seriously wrong with that file. I edited it removing everything except the opening cut and it still did not work. It looks like you need to start over from scratch. You may be able to cut - paste elements into the new family but check often in a test project.
Thanks for trying it out, I'll give it another go
Custom Window Cut |
Mon, Oct 13, 2014 at 2:32:56 PM
Custom window family glazing problem |
Fri, Mar 27, 2009 at 2:26:30 PM
Custom Family Help? |
Wed, Nov 18, 2009 at 10:22:51 AM
window insertion error |
Fri, Apr 13, 2007 at 11:21:46 AM
Custom Window Frame |
Tue, Aug 2, 2011 at 12:31:51 PM
Members: | 2017238 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
