54 Users Online (53 Members):
Forums >> Revit Building >> Technical Support >> A 360 Syncing Problem RAM 100%
31 Posts No Rating |
Revit 15 Update Release 8
Computer:
CPU - Intel i7 950 3.07GHz
Ram - 24 GB
Hard drive - 500GB STAT 6gb
I have been syncing no problem up until the last hour. The project is rather large and typically takes 1-5 minutes to sync to the cloud. Other people working in my office on the same file are able to sync no problem.
When I tried to sync the last 3 times it instantly raises my ram to 100%. I let this go over lunch and it was still trying to syncing when I got back (about 1 hour). Has anyone else had a similar problem?
Thanks in advance for any help.
Since my first Sync failed when I reopened the file it gave me the option to open my saved local file. This last time I told it to discard all unsaved work and it now syncs to the cloud file.
My guess is that I changed something at the same time someone else did and this caused the sync fail. Our internet connection is a little slow. Could this be the colporate?
Thanks again.
That only temporarily fixed the problem. Had our IT guy look at it. He talked with someone people from technical support and they demined it a hardware issue.
Revit 64bit & RAM |
Tue, May 4, 2010 at 9:02:19 AM
Ram Ram Ram |
Tue, Jul 25, 2006 at 10:20:07 AM
Can't Remove File from BIM 360 |
Wed, Apr 10, 2019 at 8:59:16 AM
Ram-revit link problem |
Wed, Oct 13, 2010 at 11:03:41 AM
Central File Syncing Issues |
Sun, Mar 11, 2012 at 5:34:27 PM
Members: | 2017036 | Objects: | 22944 | Forum Posts: | 152211 | Job Listings: | 3 |
