68 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> create/ convert hatch patterns (.pat) to revit fill patterns
Mon, Jun 1, 2015 at 3:01:04 PM | create/ convert hatch patterns (.pat) to revit fill patterns
ledgewood33
I am looking for a add-in or program or macro that helps me quickly convert my acad hatch patterns to Revit fill patterns. as of right now I am having to go into every ACAD (.pat) text file and add the line of text that designates whether its model or drafting pattern. I was hoping there is something out there that would streamline or shorten this process?
Mon, Jun 1, 2015 at 6:58:03 PM | create/ convert hatch patterns (.pat) to revit fill patterns
hugh
3.5 Stars: 4 Votes
HatchKit will do that for you via the pattern TYPE attribute within HatchKit itself or via the dropdown within the project pattern list displayed by the free HatchKit Add-In for Revit.
Hugh Adamson
www.hatchkit.com.au
Tue, Jun 2, 2015 at 9:16:13 AM | create/ convert hatch patterns (.pat) to revit fill patterns
ledgewood33
so this hatchkit can expedite the process of having to open every existing ACAD.pat (text file) in our office library and manually copy/ paste the text line of ;%TYPE=DRAFTING or ;%TYPE=MODEL.
we have many hatch patterns in ACAD and feel it would be really time consuming to go the cop/paste method
Tue, Jun 2, 2015 at 9:53:22 AM | create/ convert hatch patterns (.pat) to revit fill patterns
You can write a simple bat file to do this.
http://www.wikihow.com/Write-a-Batch-File
Tue, Jun 2, 2015 at 11:29:01 AM | create/ convert hatch patterns (.pat) to revit fill patterns
hugh
3.5 Stars: 4 Votes
Only TYPE = MODEL  require modification as TYPE = DRAFTING is the default.
The HatchKit Add-In presents a list of the patterns currently loaded to a particular project allowing the fill names, types and orientations to be managed within that project.
When the HatchKit editor is saving patterns to Revit that lack explicit TYPE or UNIT assignment  - such as those sourced from AutoCAD and elsewhere - it will add the currently setup Revit defaults to the saved fill definition file.
Edited on: Tue, Jun 2, 2015 at 11:29:54 AM
Hugh Adamson
www.hatchkit.com.au
Importing multiple fill patterns
Fri, Jun 22, 2007 at 11:50:51 AM
How to scale Hatch Patterns already loaded in file?
Tue, Apr 19, 2011 at 3:11:32 PM
Is there a way to preview .pat files / hatch patterns in thumbnails in a folder?
Mon, Jul 6, 2015 at 11:01:27 AM
imported acad hatch patterns
Sun, Nov 25, 2007 at 6:39:03 PM
Pat Files
Thu, Jan 22, 2009 at 1:26:48 PM
Page generation time: 2.7141
