37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Selection Tool 2016 Multi-level Selections
Mon, Jun 1, 2015 at 2:15:32 PM | Selection Tool 2016 Multi-level Selections
amber01aggie
This was a problem we were having earlier today and I'm posting just in case someone else runs into this.
Revit 2016
We were trying to select items on 2 seperate levels of a building from their plan views Cryingaka rooms & walls of Level 01 and rooms and walls of Level 02).  We moved the selection box across the area on Level 01 plan view and it showed the selection box and selected everything within that box.  We then go to Level 02 plan view and try to select rooms (and any additional walls) stacked directly on top of the previous rooms by holding down 'ctrl' and clicking and dragging the curser.  However, here the selection box did not display AND nothing was selected.
What we found was that when we selected items on Level 01 plan view, included were Stair:Supports.  Once those were filtered out, the selection box and selections worked properly on both level views.  I am guessing that this was an issues since the entire stair was not selected in the intial window.  Sloppy job on our end... always check your filters!!!
-A
Rule-Based Filter SELECTION
Sun, Dec 9, 2018 at 6:56:30 AM
Multi Level 3d into Single Level 3d
Thu, Jun 18, 2009 at 2:02:03 PM
selection window grabs wrong items
Thu, Jul 19, 2012 at 3:05:38 PM
filtering selections
Thu, Oct 12, 2006 at 11:52:56 AM
Multi-level buildings
Tue, Feb 17, 2009 at 2:27:05 PM
Page generation time: 0.6256
