40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Surface Pattern or Pattern Component Family for Ceiliing Linework
Sat, May 30, 2015 at 10:38:12 PM | Surface Pattern or Pattern Component Family for Ceiliing Linework
nednarb80
I am trying to model lofted and non-planar ceiling designs with linework to indicate planks, tiles etc. Initially I started with in-place components importing models from other programs. Using this method, I am able to give the object a material but cannot get a model line hatch in the material to show up. I then moved on to in-place conceptual masses. I am able to model the forms and apply materials to the surfaces and get linework for their surface patterns (this is true for imported cad as well while in a conceptual mass), however I cannot rotate or move the model lines without causing the form to change.I'm next thinking of using a pattern component family to model the linework, the problem is I haven't found a method of using the pattern component family and applying a material to the mass. Has anyone had any success applying material (with surface patterns) to imported, or, non-planar in-place conceptual masses? Any suggestions would be appreciated!
*Revit 2015
Sun, May 31, 2015 at 12:33:51 PM | Surface Pattern or Pattern Component Family for Ceiliing Linework
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Sketch draw a ceiling in plan using the ceiling tool in Revit. Use the option to give the ceiling a slope. This provides the 3D geometry you need.
For 2D & 3D linework, give the ceiling finish a model pattern that suits (not a drafting pattern). You will be able to adjust the lines to suit.
http://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU/Revit/files/GUID-EA5A34CB-21A3-45CB-B5A5-5558D88BBE94-htm.html
How to remove SURFACE PATTERN GRID LINES on imported family component?
Mon, May 20, 2013 at 7:24:19 AM
Surface pattern problem
Tue, May 18, 2010 at 9:15:56 AM
Surface pattern vs. Render Pattern
Fri, Aug 21, 2009 at 3:12:33 PM
Surface pattern
Mon, Sep 10, 2007 at 11:18:01 AM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
Page generation time: 1.3000
