70 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> .stl file creation?
Thu, Mar 23, 2006 at 4:39:29 PM | .stl file creation?
erin
5 Stars: 2 Votes
I need an .stl file to feed to a 3-D plotter. I have my project modeled in Revit, and I exported a 3-D view to AutoCAD. I then tried to export the .dwg file to an .stl file, but the AutoCAD model is made of faces, rather than solids, and won't export as .stl. Am I overlooking something? Is there any way to go from Revit to .stl? Thanks, Erin
Fri, Mar 24, 2006 at 8:38:58 AM | RE: .stl file creation?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In your export settings make sure you have ACIS solids selected as opposed to Polymesh?
Fri, Mar 24, 2006 at 10:33:47 AM | RE: .stl file creation?
erin
5 Stars: 2 Votes
Thanks. I've got solids now. Some of them won't join, but that's a seperate problem... I wish Revit would just export to .stl...
Tue, Apr 25, 2006 at 5:35:58 PM | RE: .stl file creation?
cwentworth
ACIS solid makes very poorly vectored arcs. If you save as a polymesh you can bring it into autocad and save as a vrml file. Just down load the plugin from www.xanadu.cz. I make models using 3d printers, let me know if you'd like some help. I've got experiance printing revit models in 3d. Chris www.3drp.com 714-848-4559
Thu, May 17, 2007 at 12:50:54 PM | .stl file creation?
zachjo
Hi, I am using Autodesk Building 9 and I need to get a 3d model into an STL file. Is there an easy way to get this done without having anyother software other then Revit building 9 and Inventor 11.
thanks
hoe do you export an STL file for 3d printer
Mon, Jan 5, 2009 at 5:10:06 PM
Fireplace doesn't export out into STL file
Sat, Jan 24, 2015 at 9:24:42 AM
Exporting Topo to STL as a solid for 3D Printing
Fri, Feb 9, 2018 at 4:51:22 AM
stl files
Fri, Mar 8, 2024 at 10:29:42 AM
STL export tips
Mon, Nov 22, 2010 at 10:33:34 AM
Page generation time: 0.7389
