89 Users Online (88 Members):
Forums >> Revit Structure >> Technical Support >> Tapered, Curved, Concrete Retaining Wall
0 Posts No Rating |
I have ideas, but how would you guys model this beast of a wall? Create a family using forms? Which form if so?
Also, is using a 'concrete beam' still the best (and only?) option to place a continuous foundation key below the wall footing?
Need an image.
0 Posts No Rating |
Section view
0 Posts No Rating |
another image... (sketchup)
Create an in-place, category "Wall" OR create a MASS then apply "Wall By Face"
0 Posts No Rating |
I have been playing around with both methods mentioned above.
One thing that stinks is that after creating the wall by these methods, it will not allow me to add a foundation/bearing footing even though it's listed as a wall.
I assume this means that I have to mass the bearing footing and footing key as well as the wall. Bummer. Takes the intelligence right out of the components.
Do a normal curved wall. Add your foundation and add a wall sweep to give yo the slope. Add another sweep for the fdn key.
0 Posts No Rating |
Thanks WWHub. I was actually playing around with that idea as you posted. It works well.
For the taper is it possible to have it instance based where the height, width, etc. can be adjusted in the Properties box? (See attached jpg) or do I just need to create different size sweeps for different wall heights and conditions?
Thanks so much.
You could create a profile that could be (type based) adjustable and use that in your sweep.
If you assign these to a sweep, each profile would have to be in a new wall sweep type.... In other words - you create the new type in the project browser - families then add a new sweep type with that profile type.
Creating curved retaining wall that aligns to topography... |
Thu, Dec 22, 2011 at 12:30:03 PM
Concrete tapered beam |
Wed, Jul 3, 2013 at 12:05:46 PM
CURVED WALL WITH TAPERED TOP |
Mon, Oct 29, 2007 at 4:52:13 PM
Revit Architecture 09- Topography and Retaining Wall |
Mon, Oct 12, 2009 at 4:15:33 PM
curved concrete beam |
Fri, Oct 17, 2008 at 6:10:21 PM
Members: | 2022294 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
