25 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Help - Custom Steel Frame - Revit 2016
Hi All,
i am trying to model a steel portal frame, either parametrically or fixed, of a warehouse frame i need to duplicate. i have reasonable experience in revit (mainly LT in my previous company) but now i am working for myself with full building design suite premium. (2016 version).
the column tapers up from 600mm at base to 1500 at knee, and the rafters are a composite shape.. i have drawn the frame section up in 2d autocad and attach a screen shot for example.
the flanges vary in thickness depending on the section of rafter, and the web of the section also varies in thickness.
If anyone has a parametric frame family, or series of beams/columns that might work in this situation it would be much appriciated.
thanks,
Mark
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
Look in the downloads - there are families like that here on RC.
UK - looking for a parametric steel portal frame for a factory unit! |
Tue, Apr 19, 2005 at 11:06:43 AM
using steel bearers and joists ? |
Mon, Jul 4, 2011 at 7:12:02 PM
Modifying stairs to use custom steel stair pan |
Fri, May 16, 2008 at 1:01:00 AM
Custom Window Frame |
Tue, Aug 2, 2011 at 12:31:51 PM
Warehouse Structure |
Sun, Oct 15, 2017 at 3:04:55 AM
Members: | 2026041 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
