58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Elevation Cut Plane
Thu, Mar 23, 2006 at 11:30:49 AM | Elevation Cut Plane
same
I can't seem to figure out how to change the location of the cut plane. I click on the elevation tag while in plan view, and i thought that would allow me to move the "blue line" that i remember used to appear in my drawing, but it doesn't show up. Any ideas?
Thu, Mar 23, 2006 at 11:46:44 AM | RE: Elevation Cut Plane
dalmillia
I'm also interested in the answer to this question. dalmillia
Thu, Mar 23, 2006 at 12:20:02 PM | RE: Elevation Cut Plane
same
hmm....i seem to have figured out that you need to click on the little triangular part of the tag.
Tue, Jul 9, 2013 at 3:46:48 PM | Elevation Cut Plane
RevitMaestro
There are elevation tags and there are the callout heads.  click on an elevation tag, you will activate the "blue lien" that you can stretch/ move.  if you click on the callout head, without selecting the elevations themselves, you can move the callout head, without affecting the "blue line" of the elevation.
important if youre cleaning up the sheets and need to move stuff around so they fit.
However, this brings me to a question that ive been pondering with for some time.  I noticed that if you move an elevation callout head (not the tag, leaving the "blue line" intact)  it moves that tag in all views.  For example I have a floor plan at 1/8" scale and i want the same elevation tagged in a detailed millwork plan.  when i move it to the right place in either of the plans it changes the location for both.  it would be ideal to be able to change move those callout tags independently.  Is there a way to get around this?
When I cut a section or elevation in revit, it shows what's behind the cut plane
Fri, Dec 6, 2013 at 12:47:18 PM
Elevation's primary cut plane disappered and no grips
Tue, Apr 10, 2012 at 11:49:00 AM
Defining elevation views parallel to a reference plane
Sun, Mar 5, 2006 at 2:37:42 PM
Cut Plane display issue
Tue, Oct 11, 2011 at 12:48:43 PM
Would like shadows to appear from above cut plane
Wed, May 2, 2012 at 1:22:45 PM
Page generation time: 2.0248
