133 Users Online (128 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Non vertical columns
Thu, Mar 23, 2006 at 11:17:07 AM | Non vertical columns
sweetiedarling
Hello - Any tips on how to create a column that isn't vertical? I would like to creat some angled columns so that it looks like a column tree. Thanks in advance.
Thu, Mar 23, 2006 at 2:42:15 PM | RE: Non vertical columns
hisdirt
5 Stars: 5 Votes
Sorry, I replied to your other question in a similar way as Im going to answer this one... You could use inplace families, model the columns as Blends or Extrusions-and-Voids to get the column you want, then group the column when you've finished and copy the group around (so all the columns are the same). I cant rate inplace families enough, singlehandedly the coolest thing about Revit I think. When you get the hang of free modelling in Revit you can model almost anything you need (in regards to architecture). The attatched file is an exaample of what you can get up to with sweeps and extrusions...
Fri, Mar 24, 2006 at 8:41:37 AM | RE: Non vertical columns
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Refer my blog. I've answered this question many times... http://revitrants.blogspot.com/
Vertical elements (Columns + Wall) : Need technical advise please.
Thu, Jan 12, 2012 at 2:39:02 AM
hidden columns
Fri, Mar 26, 2010 at 10:53:36 AM
Showing columns from the floor above
Mon, Jun 9, 2008 at 1:49:48 PM
Reversing Grid naming of columns?
Mon, Nov 7, 2011 at 9:32:57 AM
recalcitrant columns
Tue, Aug 3, 2004 at 7:38:46 PM
Page generation time: 8.4448
