84 Users Online (83 Members):
Forums >> Revit Structure >> Technical Support >> Printing sheet issues
3 Posts No Rating |
I have one sheet in my set that is not printing the model but only the annotation from the view. The model will print if I am just in the view - and not the sheet. I think I just played around with a setting somewhere and didn't realize what I did, but can not figure out what or where the setting is. Any help would be appreciated. Ive tried all sort of different options.
If the view is visible on the sheet while in the project, then I doubt there is anything in the print process that you are doing. Try creating a new sheet and dragging the view from the old sheet to the new one. I have seen sheets become corrupted in a project and they get lost. Sometimes they don't even show up in the sheet list. If this works, just rename/number the new sheet and delete the old one.
3 Posts No Rating |
wwhub - thanks so much! i've already tried that maybe i'll try it again with better luck.
Are there multiple views on this sheet? If so then test with just the view in question. You may have a masking rgion in a view that overlaps this. Masking regions will mask all model elements but not annotative.
3 Posts No Rating |
I don't know why that last one posted about trying it already....
I haven't used masking regions before but just played around with it - and I'm not certain that is the issue. I can work in my model and see it on my screen. Even when i go to print i still see it on the sheet - just doesnt show up in the print/pdf.
Believe it or not, there is a print order in Revit.... especially on sheets so consequently, what you see on the screen does not mean that is what will print. You don't say rather or not you may have some masking regions that may be affecting this.
3 Posts No Rating |
i do not think there are any masking regions. i never placed one for anything else.
i was able to get it to print in raster setting vs vector - which is ok for now - but i would like to try to figure out what is going on with that sheet/view......
Printing issues with masking region |
Fri, Aug 29, 2008 at 6:01:02 PM
printing sheet sets - only the sheets |
Wed, Jul 18, 2012 at 3:10:10 PM
Sheet Printing - Name of PDF |
Thu, Feb 26, 2015 at 10:07:34 AM
Anyone else have issues with slow batch printing to Adobe Acrobat? |
Tue, Jan 10, 2012 at 11:13:42 AM
Printing an A1 sheet |
Mon, Mar 18, 2013 at 3:21:14 PM
Members: | 2017148 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
