89 Users Online (89 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Plan Region nesting problem
Mon, May 18, 2015 at 5:47:43 PM | Plan Region nesting problem
sattoji
I have a project with two buildings on a site at different orientations, and planned to use Plan Regions to separate them onto different sheets. I believe this is one intended use of the Plan Region tool. However, I also have a combination of normal and high windows, and would like to show both my doors (6'-8" tall) and high windows (sill height over 6'8") on the plans. Since Revit 2015 won't let me nest Plan Regions, is there any workaround for this?
MacBook Pro 2.66 GHz Intel Core i7 running Windows 7 Pro 64-bit on Parallels 6
Mon, May 18, 2015 at 5:51:14 PM | Plan Region nesting problem
sattoji
Sorry, I may have solved my own problem already - looked at a previous project and noticed that I used Scope Boxes to create the separate views, not Plan Region...
"...nevermind!"
p.s. would like to know how to delete my posts on this forum, thanks.
Edited on: Mon, May 18, 2015 at 5:52:49 PM
Mon, May 18, 2015 at 6:04:23 PM | Plan Region nesting problem
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Duplicate your floor plan, make one for building A and another one for the building B. Use Crop Region (not Plan Region) to 'remove' unwanted building from the view.
Use Plan Region to override the View Range (show high windows, for example).
EDIT: Yeah, scope box will work too.
Edited on: Mon, May 18, 2015 at 6:42:49 PM
Plan Region problem - walls/slabs/framing displaying outside the region boundary
Tue, Jun 23, 2009 at 4:46:32 PM
PLAN REGION PROBLEM
Wed, Sep 10, 2014 at 11:15:22 AM
11
Plan Region Problem with Columns
Tue, Mar 25, 2008 at 4:04:09 PM
Masking Region Fill Region Problem
Mon, Mar 10, 2008 at 11:06:24 AM
Plan Region
Fri, Jul 21, 2006 at 4:23:10 PM
Page generation time: 1.7825
