126 Users Online (125 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit Architecture 2015 - Families not loading
Fri, May 15, 2015 at 6:32:07 AM | Revit Architecture 2015 - Families not loading
joeinck
greetings,
i have been experience this problem through a couple versions of revit.  when i try to load a component from the structural and a few other content libraries i get the message as shown on the attachment.  any ideas why revit can not load families that it ships with its product?
Fri, May 15, 2015 at 6:52:17 AM | Revit Architecture 2015 - Families not loading
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
It is exactly what the error says, you are trying to insert a component family however whatever family you have chose to import is not a component.  Just go to Insert>Load Family and do it from there and you can insert any family type you want.
Mon, May 18, 2015 at 3:53:28 AM | Revit Architecture 2015 - Families not loading
joeinck
Thanks...kind of odd that when laying out beam systems that, while working in the command, you can not load families.  do you know if people create template files that have all these families pre-loaded and more importantly activated so you can select them during a command?
thanks again,
j
Mon, May 18, 2015 at 1:21:35 PM | Revit Architecture 2015 - Families not loading
Plywood-Section has nothing to do with beams..... Read the error message!
Mon, May 25, 2015 at 8:59:34 AM | Revit Architecture 2015 - Families not loading
joeinck
Well, plywood is found in many structural systems, Truss joist being the most popular.  Also plywood is often 'sandwiched' between 2x lumber, thus creating a stronger resistance to deflection in the Beam.  So while drawing a sketch in plan view of a number of these 'sandwiched' beams it would be nice to draw the plywood section in a similar fashion as the 2x lumber. The previous response address the issue and I have learned of the work around.
thank you for your time on this matter.
Mon, May 25, 2015 at 10:44:09 AM | Revit Architecture 2015 - Families not loading
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
You can create a family like that – double beam with plywood in-between, and draw the entire assembly with just one command.
REVIT 2015 DELETE FAMILIES FROM FILE BEFORE OPENING IT - UNRECOVERABLE ERROR
Thu, May 12, 2016 at 7:57:16 AM
A fatal error loading family into project overwriting existing
Mon, Jun 22, 2015 at 8:03:39 AM
Cant load families
Tue, Jan 5, 2010 at 12:05:33 PM
Differences in families while loading them into project
Wed, Oct 27, 2010 at 7:02:18 AM
Loading families results in a serious error?
Sat, Mar 12, 2016 at 7:09:22 AM
Page generation time: 2.8995
