81 Users Online (80 Members):
Forums >> Revit Building >> Technical Support >> Base Project template
208 Posts No Rating |
Hi all,
I am looking to create a base project template to be used whenever we open a new project.
As we are unable to create library elements for walls other than within the project, the project template needs to be updated each time a new wall type is created.
Because of the type of architecture our office creates the walls we usually develop include a number of different profiles. Corbels and mouldings both internally and externally.
Is it better to create the walls with these profiles already in place or is it wiser to just have a range of wall core types and have the profiles stored within your library?
What experience have others had with this?
cadjockey
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
I would go with the second option, it just gives you more freedom.
Template to Project |
Tue, Jul 31, 2018 at 2:25:32 AM
Central model - extract object with Project Base Point |
Mon, Sep 23, 2013 at 2:25:40 AM
Visible project base point |
Wed, Aug 7, 2013 at 4:32:58 AM
save new template from project |
Tue, Nov 21, 2006 at 7:16:15 PM
Changing a template to a Project |
Tue, Feb 2, 2010 at 7:03:23 AM
Members: | 2017294 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
